mep1811
Gentleman Adventurer
http://lifttrax.com/specifications/
Looks like it has promise
LiftTrax 4000R
The LifTrax 4000R (SUV version) is built to hold the weight of common 4×4 vehicles up to 8,800lb (4 tons) in weight, such as the Toyota Land Cruiser, Jeep Cherokee, Land Rover Defender 110 and Land Rover Discovery.
LiftTrax are manufactured using high quality materials: Their reinforced PVC coated- fabric shell is covered by 1/4″ (6.4 mm) thick rubber ribs for optimum traction.
LiftTrax can be connected to each other for extended recovery length.
Your LiftTrax 4000R kit contains:
Two 44” X 20” (110 x 50 cm) pneumatic traction mats
Two pre installed replaceable bladders
1 carry case
2 inflation adaptors
One user manual
LiftTrax 4000R kit weight: 18lb (8 kg)
LiftTrax 4000 kit size: 20″x 8″ x 8″ (50cm x 20cm x 20cm)
Max allowed pressure: 10 PSI
Methods of inflation: Air compressor, CO2 canister, hand-held pump or manually.
This one is a bit out of left field but it’s a very versatile product. Deflated they
can be used as a very basic aid to traction but inflated they have multiple
uses. For rock crawling they can smooth the approach angle and while
offering no real bridging capability they can just fill the ditch! And they can be
placed under a beached truck and used as a basic air-jack. They are rated
up to 4tons and in the event of a puncture the inner bladders are available
separately. Once deflated they just roll up and store almost anywhere.
SIZE: 1.1m x 0.5mm, weigh 8kg a pair
VERSATILITY: Not the obvious choice, but offer a good mat, a comfy
bench seat and a play-float on the beach!
LiftTrax 4000R
1 carry case
One user manual
