I just picked up my 2000 E350 SD w/PSD.
Would LOVE to 4X it but really cant justify the cost vs use ect...
So I am thinking 2X4, looking at the camburg, with like 285's and
locking the rear. Any thoughts on the Camburg set up???
I looked at them. They have an awesome suspension setup that I looked into for my 96 culb wagon. But if I remember correctly they cost the same as a ujoint 4x4 setup and your still not 4x4. All beit you still need axles and the other things on top of the ujoint kit. Ill have to double check there website when I get back to work.
I installed 3" fabtech lift springs off a f150 I found at a junk yard. I left the rear stock. It helped clear my 265s but the alignment and handling could be better with bent beams. Autofab can bend beams for 600ish I believe and you can install coils like me with bent beams and have the alignment issue resolved. I just saved up for 4x.
