cruiseroutfit
The purge kit will do the trick!
Can you fill us in on that? Is it just used to purge the line of oil if its gets any one there before it gets to the Solenoid?
look here for the ARB pdf
http://www.arb.com.au/resources/pdf/airLockers/4-04.pdf
If you do pull the locker, pay attention to how "tight" the locker feels coming out of the third, if the preload is too loose on the side bearings it can cause an ARB to leak, especially in a Toyota 8" (8.4") rear end. This is a very well known issue with Toyota rear axles and ARB's due to axle housing deflection.
That may be what is wrong with mine. I've had a problem where the locker is venting air out into the axle and then it is released through the axle's breather. Do you have any pointers to this well known issue as I'd like to read up on it. Thanks!
