Armadillo Sharpwalker f550
SootyCamper
This Chinese f550 build has peaked my interest.
F550 with super singles running BFG AT KO2.
Parameters:
Sharpwalker
Vehicle information:
Overall length: 5,995 mm
Overall width: 2,345 mm
Overall height: 3,050 mm
Total weight: 5,490 kg
Minimum ground clearance: 300mm
Approach angle: 33 degrees
Departure angle: 23 degrees
Longitudinal passing angle: 30 degrees
Fuel tank: 151 liters
Engine: Ford 7.3-liter 2V DEVCT V8 gasoline engine
Maximum power: 350 hp
Maximum torque: 635 Nm
Tires: 295/65R20, 5 (including spare tire)
Transmission: 10-speed Ford TorqShift® automatic with mode selection
Drive form: Part-time four-wheel drive
Cab: Single row cab, 2 seats
Structure and configuration:
Capacity: 2 or 4 people
1 double bed 1920x1315
Dining table deck for 4, convertible bed 1840 x 1050
standard kitchen
bathroom with washbasin
locker
Box:
The box body and the chassis frame are flexibly connected by a three-point torsion balance mechanism
The box is a sandwich structure with broken bridge and heat insulation
Internal and external ultra-high-strength glass fiber reinforced plastic sheet
Windows: Proprietary to Amodillo with imported brand marine shades and mosquito nets
Sunroof: can be opened inside and outside, equipped with imported brand sunshade and anti-mosquito net
Main door: exclusive to Amodillo, equipped with imported brand electric door lock, password open and magnetic card open, mosquito net
Stairs: Electric two-step stairs
Flooring: Teak Flooring
Power Systems:
Amodiro fully automatic high-power hybrid power supply system
Imported brand 5 kVA inverter charging machine
Imported brand automatic intelligent power management system
Imported brand switchboard
Imported brand battery isolator
1200Ah, 12V, LiFePO4 battery pack
5 solar panels 550 watts
Imported brand solar charger
Mains access port, outdoor power port
switch, power supply system emergency switch
Current monitor
LED interior lighting
Air conditioning and heating systems:
1 split type DC inverter air conditioner with a cooling capacity of 2.2 kW
Exhaust system
Imported brand 4kw gasoline oil heater heating system
water supply system:
260 liter stainless steel fresh water tank
Imported automatic water pump and waterway system
Gravity water inlet, homemade
Imported brand 5kw fully automatic gasoline hot water boiler
water heater
Kitchen System:
76 liters 2 refrigerators, refrigerated and frozen can be switched
Imported brand 2.1kw single eye induction cooker, exhaust hood
Imported brand built-in microwave oven
Full set of kitchen utensils
Stainless steel washbasin with stainless steel hot and cold water faucet
Toilet equipment:
shower head
Imported brand full ceramic electric suction toilet
Imported brand ceramic washbasin, with imported brand hot and cold water faucet
Exhaust system
Sewage: 60+35 liter stainless steel grey water tank with level sensor; 85 liter stainless steel black water tank with level sensor and electric drain pump and manual drain valve
Entertainment system:
32-inch TV with 5G router
Imported brand bluetooth speaker
Other configuration:
Natural latex sofa and 3D printing + latex mattress
Rear external spare tire
Reverse image
Outdoor pull-out kitchen
LED side lighting
through hatch
side sunshade
radio station
front winch
2 external storage boxes at the rear
4 off-road spotlights
Four-way monitoring
washing machine
Optional paint color
(white, cement grey, matt grey, desert yellow, green, olive green
20220730093530376.jpg20220730093530430.jpg20220730093531901.jpg20220730093658405.jpg20220730093658823.jpg20220730093658719.jpg
SootyCamper
Priced at 2 million Chinese Yuan
I'm mostly interested how they're running a f550 with bfg super singles.
Curious what you guys think, cool to see a non American builder utilize f550
dbhost
Interesting rigs for sure, but agree, these should be rolling on duallies for that weight.
Mitch Bears
