ZioEdo
Hello All,
I am thinking about selling my 2019 Tacoma with 3300 miles. Turns out my wife is not into extreme adventures and now i need to rethink my next steps. I am thinking of building a larger truck which can tow my travel trailer. That way i can park her in comfort and i can go off on short satellite trips.
I have invested ~80K in my build not including my labor. What do you think is a fair price? Here are the details.
Stock Truck Details
2019 Toyota TRD OFF Road DCSB, 6 Speed Manual, Rear Locker, 4.30 gearing, Leather,
Sunroof, Dual Climate Control, Navigation. 3,300 miles
Build Details
Alucab Canopy Camper
Rear Molle boards
Shadow Awning
Slide out table and tray
Netting on sides and rear door. Rear door not installed
Low profile load bars. Not installed
Rear door tire carrier, not installed
Wired for solar with Anderson connector on roof
Suspension
ARB Old Man Emu 2” Lift with 600lb. heavy duty leaf springs, ARBOMETAC16BP51B
SPC Upper Control Arms
Armor
ARB Summit Front Bull Bar Bumper
ARB Summit Front & Side Rail Protection
ARB Summit Rear Bumper
ARB Under Vehicle Protection
Performance
SOS Performance Front Brake 6 PISTON FRONT BIG BRAKE KIT TR325.6TA
ARB Front Airlocker ARBRD111 30SPL 3.91&UP
ARB Compressor CKMA12
Lighting
Baja Designs Squadron Pro - BAJ497803 – Ditch Lights
Baja Designs S2 Pro Flush mount --Backup lights
Baja Designs S2 Sport Red Lens – Exterior Camper Light
Baja Designs S2 Sport Clear Lens – Exterior Camper Light
Baja Designs LP9 driving combo LED lights BAJ320003
Electrical
Odyssey Battery ODY31M-PC2150ST
Camper integration
Truck Battery Isolation- Blue Sea 30A Breaker Disconnect
Selectable power source- Truck or Auxiliary Input
Auxiliary Input – Blue Sea 12V Female Receptacle
10 amp Resettable Thermal Fuse
Blue Sea Waterproof Circuit Breaker Switch Panel
Blue Sea USB Charge ports (2)
Blue Sea 12V Charge Port
Blue Sea Mini OLED Exterior Temperature Monitor
(2) #2 AWG Carol Welding cable ran from truck battery to camper
(8) extra 12AWG conductors ran from engine bay to camper
Baltic Birch Floor with Threaded Inserts, Marine Varnish w/non skid
Baltic Birch Camper Inserts, Marine Varnish
Bantam SPOD with HD Panel, one position open
Recovery
Warn Zeon 10S Winch, 10K lb, Synthetic Rope
ARB Recover Point, 8 Ton Capacity
Hi Lift Jack and Mounts
Factor 55 Ultra Hook and Rope Guard
Factor 55 Hawse Fairlead
Interior
Goose Gear 60/40 Seat delete
Expedition Essentials 3TPAM Accessory Mount
Weathertech Front Floor Mats
Tires
(5) BF Goodrich LT265/75R16123/120RAT/TAKO2LRE
Spare Mounted on Steel Wheel, Stowed under bed.
Miscellaneous
SLEE Compressor Mount
Power Tray – SPOD Mount
Cali Raised Low Profile Ditch Lights Mounts
Stock Truck Details
Build Details
Rear Molle boards
Shadow Awning
Suspension
Armor
Performance
Lighting
Electrical
Camper integration
Recovery
Interior
Tires
Miscellaneous
