Atlantic British unrolls Terra Firma 18" steelies for LR3
TexasTJ
Climbing Nerd
Did you replace the TPMS with the original OEM one? or is there specific one that you used? because I just have placed the order and total have no idea about these TPMS! Thanks!
Using the DII to turn off the TPMS is the best mod you can do.
Your TPMS from your LR wheels should fit in the steelies just fine if you are looking to just swap them ever at the tire shop. Just make sure the ECU is reading them before you drive away from the shop so it's on their dime.
Modding your truck to fit 17" wheels "IS" the best mod you can do.:unsure:(y):ROFLMAO:
xiaohan1995
Hey Thank you guys! Another issue that i am facing is the Center Bore. Land Rover's 72.6 mm. But I didn't find the Terrafira's Center Bore. I guess it should be slightly bigger than LR4. I need those diameters' information because i am worried about the vibration. Thus A hub ring is necessary to put on the rims!
