Autohome Maggiolina Airlander
Small (a little smaller than a full size mattress)
Gray canvas exterior, white shell
2 cranks (1 standard, 1 long throw)
2 spare plugs
2 ladders (1 factory, 1 aftermarket telescoping)
Extra grey tent patching material
EXTERIOR
Exterior has some wear and scratches from use, nothing that affects the function of the tent itself. No cracks or deep gouges. Small 1mm gouge on right side that can easily be filled. Tiny .25mm hole from fabric wear in corners- common issue. The hole doesn’t leak but you can easily patch and reinforce the corners.
INTERIOR
Interior has some nicks in the headliner caused by storing the ladder inside. One of the YKK zippers sometimes sticks but always works. Mattress was replaced last year with higher density foam, cover was also replaced at the same time. Sheets and blanket always used over the mattress.
Everything will be fully cleaned and detailed for the buyer.
Asking $1800 picked up in San Jose CA. Please email me at spcnguyen (at) gmail.com as I don't often check PMs here.
2 spare plugs
EXTERIOR
INTERIOR
