AWD Chevy 1500 Adventure Van
SBaircraft
In this thread, I'll post pictures and details from my AWD Chevy 1500 project. I recently moved to northern California and I needed a camper van to support my weekend adventures. I also needed to preserve the original cargo function because I also use the van for work. The result has been a good work/play compromise.
SBaircraft
I had a hard time finding an AWD cargo van so I bought an airline ticket to Duluth, MN. After looking at several vehicles, I bought a 2012 model that had been lightly used as an IT support vehicle. After getting it home, the first step was to remove the original shelving.
SBaircraft
Backup Camera
I installed a simple backup camera system which has been wonderful, now that the rear windows are covered. I used a cheap relay to turn the system on whenever the backup lights illuminate.
SBaircraft
Electrical (Part 1)
The diesel version of my van comes with a second battery, mounted to the frame, just behind the driver seat. Sure enough, my frame was drilled for the same battery mount! I added a GM battery mount, Optima deep cycle battery and solid state isolator. I mounted a power inverter and fuse box to the bulkhead.
SBaircraft
Fantastic Fan
The fantastic fan was really easy to install. My roof isn't flat so I made some plastic spacers for the low areas. The stock lid is dome-shaped and tinted. However, I ordered another lid that's flat and opaque. The new lid should be a little more stealthy but I haven't found time to install it yet.
SBaircraft
Folding Bed/Couch
I'm not very tall (5'9") and I originally planned to sleep crosswise. However, I found this awesome bed and completely changed my interior layout. It mostly gets used as a couch while eating, working or hanging out. At night, it comfortably sleeps two. It even folds out of the way to make room for motorcycles and cargo.
The stock bed is 79 inches long which was a little too long for my needs. I called the manufacturer, near LA, and they agreed to make me a shorter bed for no additional cost! After test fitting the bed, I mounted it to a simple oak rail.
SBaircraft
L-Track
After a long debate between E-track and L-track, the L-track won out. Wow is it handy! I can't believe I got by without a proper tie-down system in my last van.
SBaircraft
Storage and Desk
For storage, I installed a shelving unit from Adrian Steel. I made a table/desk from 3/4" plywood and Formica. The table folds up when not in use and it helps secure items on the shelves while I'm driving around.
SBaircraft
Awning
I installed a Thule roof rack and 8ft ARB awning. It's a very nice awning but I rarely use it. If I had to do things again, I'd probably skip the awning and keep the vehicle a little more stealthy,
SBaircraft
Curtains
I covered the rear windows with reflectix. I found some that was black on one side, so it's pretty much invisible behind the window tint. I made curtains for the sliding door and bulkhead. The curtain material came from Walmart and I ordered plastic curtain track online.
SBaircraft
Fridge
I was originally going to stick with my free (dumpster diving trophy) cooler. However, my girlfriend really cared about food so I purchased a Dometic CFX-65DZ. It's been surprisingly energy efficient and quiet. It's much larger than I need but the freezer compartment is worth it! Now every hike ends with an ice cream bar.
The fridge was a little too wide but it fit perfectly after replacing the handles with tie-down rings.
SBaircraft
Electrical (Part 2)
After installing the fridge, it was necessary to beef up my electrical system. First, I added shore power. When the vehicle is plugged in, the fridge automatically switches to AC power and a Noco Genius battery charger trickle charges the house battery. It's also nice to run an electric heater when I'm plugged in at a friend's house.
I also installed a solar charging system. I used two Renogy monocrystalline panels at 100 watts each. I added a ladder so I can clean the panels regularly. Now I just need to add a second house battery...
SBaircraft
Kitchen Pod
I found a sink/stove unit, water jugs and aluminum cabinet that fit together perfectly! The table top and folding leaf were made from 1/2" plywood and Formica. I also whipped up a 6" wooden base and mounted the kitchen pod to the L-track with threaded studs. It should quickly come out when needed.
I still need to finish the plumbing and wiring but hopefully I'll have running water by the end of the week!
Corneilius
Nice build. Gotta love having a CNC. I especially like the adrian steel shelf/ flip down counter top. A buddy runs a similar setup, I sent him the pictures.
Im also a fan of the dedicated propane cubby, have you got anything in there to keep them from rolling? It would drive me crazy.
vertical.dan
