Bajablazer85
Post #7 - Engine
I thought the brake kit was the fun part. I was kidding.
Teardown of the Camaro's 3.4L V6 began.
The parts pile is accumulating...
Short block achieved!
My buddy came over to poke around and help out.
Keeping my parts organized, I'd thank myself later.
I found that everything internally is essentially brand new. At just over 100,000mi, I didn't drive the Camaro for long, but whoever owned it before me took very good care of it. With the exception of maybe not using the correct coolant ratio, as the water jackets seemed to have excessive rust.
Off to the machine shop! Crank bearings would be polished, but kept at factory sizing. Cylinders were bored to 0.030" over. The heads were decked, and valves re seated. I had considered a port and polish and/or cam, but figured I could do that in the future if I wanted more power.
Supplementary build info: oil pan gremlins.
The difference between the 4x4 and 2x4 oil pans presents a challenge for packaging. The 2x4 oil pan on the 3.4L will hit the front differential. The seemingly obvious solution is to swap the pans, since the 2.8 and the 3.4 are the same engine architecture, right? Yes and no...
The below comparison shows the difference between 2.8 oil pan (left) and 3.4 oil pan (right) at the front seal. The difference is due to the design change from vee-belt to serpentine belt accessory drive.
This is explained more in depth here ----> http://www.s10forum.com/forum/f106/3-4-crate-engine-parts-list-and-info-428709/#post6768540.
Here's where things get weird for me. I don't know how, but I was able to snag a 4x4 oil pan with the serpentine belt style front cover seal from this Blazer.....with a V-belt. A serpentine belt style front cover seal design shouldn't technically exist on a 4x4 vee-belt truck, except on the H/T 3.4 V6 offered from GM Performance parts, which is illegal for street use in Ca. For all intents and purposes, this is a unicorn.
I'm not going to wonder too much about how I got what I needed, and not having to do a custom oil pan. But it just seemed like one hell of a lucky find for me.
While the motor is at the machine shop, I had some downtime. Did some washing and started rebuilding the 3.4L intake manifold. All 6 fuel injectors were sent to Doctor Injector for flow testing and rebuilding. Since new injectors run upwards of $60 a piece, this was dollars saved. And it turns out, they could very much use some TLC.
And then my jewels arrived....
