jscherb
The Trail Kitchen can mount in anything that's got a relatively flat floor and has about 17" x 25" of space on that floor. Mounting it in the 2dr turned out to be pretty easy using the rear seat brackets and one of the factory tie-down points (the same tie down point is used when it's installed in the 4dr).Well, NOW you've caught my attention. For some reason, I assumed it would only fit in the 4-door.
So glad you've now got access to a 2-door to use as a test mule for new ideas!
I've been trying out a bunch of new ideas in the 2dr, a week ago I posted about fitting the Overhead/Swing Down Molle panel into it. Because the 2dr roll bar is different from the 4dr roll bar I had to make new upper brackets for it, but they only took a few minutes to build. After installing it I decided to recommend to MORryde that they do not release a 2dr version, and here's why:
Because the back seat is so close to the rear of the Jeep, part of the panel sits above the head of back seat passengers, which I think is a safety risk. I suppose it could be released as a product with the disclaimer that it's only for use in a 2dr with the back seat removed, or with no passengers in the back seat, but in today's litigious world all it would take is for one child to cut his head on the metal after dad goes too fast over a speed bump and lawsuits would probably ensue, even if a disclaimer was part of the product instructions.
So if any 2dr owners want the panel in their Jeep that they've removed the back seat from, they can make up the necessary brackets themselves, they're not too hard to make.
