It's finally time. After owning a Canadian M101 for the better part of 6 years I am finally ready to build her out as a base camp trailer. My son is now 7 and started cub scouts so we will be camping a lot. I wan't my trailer to contain all my camping needs for the trip and storage when we get home. We went on a quick over nighter last weekend to Cub World and jeez what a pain getting all the stuff located, loaded, deployed, taken down, reloaded, and unloaded. I was gone a little over 24 hours and probably spent 20% of my waking time loading, setting up or taking down.
So here are my ideas after many years of doodling, following others and head a lot of head scratching.
1. I wan't my RTT mounted at least 6.5' high. This does three things; first it allows maximum benefit of the RTT changing room (actually could be a secondary sleeping area), secondly gives more accessible room/storage underneath the RTT and lastly gives me a perfect mounting point for a canopy on the driver side as the RTT will fold out the passenger side. I know the center of gravity is going to be effected big time but this is a base camp trailer and not a hard core off road take me anywhere trailer. Dirt roads a few creek crossing is all she is going to see. Any thoughts on this CG issue.
2. I had hoops built a few years ago by Jim B of rock solid offroad http://solidrockoff-road.com/index.php The hoops are made of typcial roll bar DOM steel. I will have front and rear hoops connected to the trailer corners. A spreader bar will run horizontally and connect the two hoops. There will a "false" middle hoop that only ties into the spreader.
3. There will be an opaque lexan roof on top and custom sewn rollup cloth sides probably made out of sunbrella. Sides will snap or cinch down to the trailer.
4. Driver side between the hoops will be custom made cabinets 15" deep, 60" wide and 30" tall. These cab's will hold cookware, dry food, and other essentials. This cabinet space will be broken up as follows; two bottom cabs each 30x15 with drop down doors to make a work surface and two top cab's 30 x 15 with typical cabinet doors.
5. A 20" x 10" x 48" pullout will be built into the trailer on the driver side in front of fender. A box will be built on the outside of the trailer in front of the fender to accommodate 48" sliders. This will pull out will be perpendicular to the trailer side and have a three burner stove and wash tub. It will have double sliders one set of 48"ers to pull out the primary section (housing the cook top) and a second set of 30" sliders for holding the wash tub. I will plan for an attached fold down leg at the end of the primary pull out for support. The slider will be fully boxed/enclosed inside the trailer bed with sheet metal.
6. Rear of trailer will get a tailgate and one large slide out (48" sliders again) on the drivers side for a fridge/freeze and a storage box. This slide out will be 48" long, 21 inches wide and 18" high. The remaining 15" on the passenger side of the slide out will be left open for gear storage (chairs, tables, etc....)
7. Front of trailer gets a nose box for two batteries, inverter, and system controls.
8. A 20 gallon skinny rectangular water container will be mounted in front of the nose boxe up against the trailer body much like the AT trailers.
9. Trailer tongue will be extended 2' for better towing and backing.
10. Propane pancake tank on passenger side in front of fender.
11. Two Jerry Can holders on each rear corner.
12. 2x2 hitch receiver welded into rear cross member for bike carrier, etc...
13. 2x2 receiver tube welded to each corner of the trailer frame facing out to the sides. These will accept a standard crack down trailer jack with flat foot for stabilizing and leveling the trailer once parked.
She is going to be heavy but I am going to put disk hubs on the axles and also extend the wheels via different backspaced rims or adapters. My major concern is the how it will handle at highway speed given the height.
Okay long post but fire away and shoot holes in any of my ideas, add to them if you like or flame me I'm a big boy. No offenses taken.
Cheers,
ALF
Cheers,
ALF
