battery performance numbers for Dometic CFX-65DZUS
jk6661
For those considering whether to buy a fridge vs. a cooler, I thought I'd post some preliminary data on how long my new Dometic CFX-65DZUS lasts on a new 100 ah deep-cycle battery. I plugged the fridge into 120v ac and cooled it to 25 deg. F. I then connected it to the fully charged battery and left it running in my 68 deg. living room. I opened the fridge three times a day for 30 seconds each time to simulate real-world use (at least for me). After 72 hours, the battery voltage had declined from 12.75 to 12.2.
Caveats: I haven't used the fridge in the wild yet, and obviously hotter/colder outside temps, a warmer/colder fridge temperature setting, and opening it more/less will affect performance. Ditto if you're charging the battery periodically with solar or an alternator. But for what it's worth, there you go.
kerry
For comparison purposes, here are the results of my test of a Unique 60l posted in my thread on that frig:
Temperature was over 90 degrees yesterday. Frig was on a 35ah battery for 45 1/2 hrs and used 60% of the charge in that time. (battery was at 11.94 volts when I disconnected it) If my math is correct that means it used about .5 amps per hour over that period. Frig only had 6 small water bottles during that time and they were already cold from running it on 110 volts.
TwinStick
If the fridge is full & everything was already cold, it will cycle less than an empty one. 3 days is good I think. I will be doing this soon myself. We have an 82 & 50 qt ARB. Just ordered a Cabela's X-900 Gp 31 tonight. I will fill them full of water & beer & do the same test. Hope the new batt does good.
jk6661
The fridge was empty for my test, but you're correct that full is better for minimizing cycling.
dcg141
I ran mine for a 3 day weekend using a Goal Zero Yeti 400 chained to one of these https://www.amazon.com/dp/B01BKY05MC/ref=sspa_dk_detail_0?th=1. I used a 100 watt portable panel during the day. I never really drained the system beyond 60%. Make sure you put the battery threshold on low. Mine came set on high and would shut down with 80% battery still left. I get the unit cold empty then load already chilled food.
KSL22
Went to hard wire my CFX65DZ and cut off the cigarette lighter end before confirming pos / neg. Any one know which wire is which? One of the wires is stamped with wording and the other is blank.
WonaWarrior
