K2ZJ
http://www.colorado4x4.org/vbb/showthread.php?t=175719
Don't know him, I just saw it and thought of this thread.
My gut says that if you're going with OME springs I'd go with the OME shocks.
I liked my bilstien 5100s before I killed them. Really like my QA1s, but that's probably overkill.
I had this very discussion on another site a while back.
Consensus is that trail only trucks, most go with the Bilsteins (they're harsher). For DD or weekend warrior offroading, the OMEs are much smoother and even (as in cushier) making them a good choice overall for tarmac and offroad (they can take abuse). So for mostly tarmac, they deliver a smooth ride, but if you want to venture off into the wilderness, they're up to it.
I have OMEs and they're solid and smooth. They're not soft, just a consistent, even compression rate from extended to compressed.
I've hit potholes at 70-80 KMH (5" lift DPG/RE hybrid on 32s) and they didn't throw me off the line.
Also, I'm sure you know this, but running 35s would mean tarmac only. On 32s, with a true 5" of lift, I rip my fender flares off on the trails (no fender cutting).
what size tires do you run?
what type of driving you mostly do? (offroad & trails or daily driver & lots of highway?)
TARMAC= ashpalt..( on the road)
FYI. BDS does offer their 4 link front a la carte. If you are a member on www.jeepforum.com they have a discount in the vender section for members. You can also get it without the arms if you choose to make your own. The directions to mount the kit can be found online so locating the crossmember is doable very easily.
This is the route i am going. I will be making my arms out of heat treated aluminum hex bar stock or round stock.
Is that price for the kit with springs? I know the BDS long arm kit is significantly cheaper without the springs.
Also poly performance makes a 3 link and a 4 link for cherokees.
