Bed Cap or keep my bed rack
roving1
The Thule Xsporter is rated at 204kg 450lb. It's the only one CVT sells. Poking around several other flavors have much less capacity and at a glance look similar. Some of those were indeed rated much less in the 200lb range.
FWIW mine has done about 40 hours of 4-lo on trails I could not go faster than 1st gear in without bottoming out and it has remained rock solid. Plus about 5000 miles of other trails and highway. I had it way up to be able to stand under the annex too which gives the weight more leverage against the frame. I have not even had to tighten the mounts yet. I'm 300+lbs and when I climb on top of the rack it is completely rigid.
I honestly thought this was going to be awful and I would be worried about it constantly shaking around and getting worse over time. Very surprised it is more robust than I imagined.
vertical.dan
