Bedlining Vehicle Bodies
jh504
adrenaline503 said:
Thanks for all the info, I wonder if I should do it in black, gray or match the blue color of my truck.
Just my opinion, the ones that I have seen that are actually colored, after a while dont look so good to me. I think it kind of looks cheap, but that is a matter of personal taste. I would go with black or grey. I bet grey would look pretty good against the blue.
Whatever you end up with post a picture to let us know how it turns out.
adrenaline503
Yea, I was thinking gray. It will be a while, but I'll get it done.
cruiseroutfit
AlpineSMB said:
Cruiseroutfit....
where did you get your Taco sprayed? Any other comments? Looking for someone here along the Wasatch Front to spray my rear rocker panels and front bumper on my SMB
thanks,
-d
You have a PM :D
cruiseroutfit
jh504 said:
...By the way cruiseroutfit, I would love to see some pictures of your Taco, that looks very nicely done.
I need to take some recent photos... eventually I'll do a build thread on the truck :D
DH2002
I was thinking about doing the bottom edge all the way around my truck to protect from rocks in Alaska since Barrow only has gravel roads another thing I gotta convice the wife to do
jh504
Please do, I have ran two tacomas in the past, and I would like to see what you have done with yours.
JRhetts
"Bedliner" on Vehicle
I sprayed the lower panels of my Ford F-450 and camper [below horiz line from front door to rear of camper in attached picture] (~ $500.00) to reduce rock chips. After a lot of research, I went with Speedliner, as they were the only ones who would use Ford paint in their spray-on material, meaning that the spray-on material was one color throughout, well-matched to the rest of the vehicle - and chips if they happened would not reveal another color underneath.
I needed to do this because driving on gravel/dirt roads and tracks were rock-blasting the lower sides -- so much so on the leading edges of the front fairings that the fiber glass was being eaten through. When I tried the 3M film, it got eaten through in <3000 miles.
After 40,000 plus miles, you cannot even see any wear in the spray-on material at those points, the paint match between the sprayed lower part and the upper doors and house are simply GREAT.
Using someone who is really experienced is vital. I would not use just anyone. I'd want to see their work on a comparable job before doing it.
Weight addition is minimal. I got a quote for doing my whole camper, which I will probably do on the next one to reduce "desert pinstriping", and the estimate was that it would add 50# by doing the whole camper unit.
jim65wagon
I can attest to the quality of the color match on Haggis' truck. It looks killer up close, the color is a proper match to the green on the truck and it's holding very well....
As for the durability of Rhino, (it's the bed not the body) this was done to our truck two weeks after we bought it new in 2002. It's been through countless rains, snows, sunny days, loads of firewood, gravel, sand, dirt, trees, mulch, camping gear, fishing gear, oily things, greasy things, dead things; and other than a few cuts where we got a little overzealous in our shovelings it's still in great shape.
xander69
