arlon
I have an AWD Astro van (2" lift) that I'm slowly converting into a camper for some rocky roads travel in West Texas. Biggest issue will be sharp rocks and mesquite thorns. I think the E tires would be MUCH tougher than the "P" rated tires. Issue is that the E tire I can fit (at least think I can fit) only comes in a 225/75/16 size while the "P" tire is a 235/70/16.
To get the E tire I have to give up a little width and gain about 1/2" in diameter (3.73 gears should still pull them). Curious what your thoughts are on strength vs footprint? I also assume my daily driver ride quality will suffer a little with the E tires but economy might actually improve if I keep the pressured up. Load capacity with the E's would never be a concern, I like that.
Also posed this question on the astrosafarivans site so if you see it there, no need to answer twice...
