FellowTraveler
6.2 or 6.5
Be advised all 6.5 turbo diesels up to May 1999 are prone to failures like cracked blocks, any GM 6.5td built after May 1999 are enhanced stronger block larger bearing caps. Hummer H-1 had kept using the older left over failure prone 6.5 td well into mid 2000 (s) if I remember correctly.
The enhanced GM 6.5 td can be found in some burbs, pickups and vans from May 1999 up 2002, I forget what year the military started using the enhanced 6.5.
To the best of my knowledge all May 1999 and up 6.5's use 7 bolt bell housing for 4L80e.
There are varied thoughts on what mods are good on the 6.5, however, I like Fluid damper balancer, timing gear drive, remote pump driver when using electronic injection pump, hi-pop injectors, good tune, 3" or 4" exhaust, higher flow canister air filter, evans waterless coolant, bypass oil filtration, synthetic fluids. I still use 1 oz 2 cycle oil to 1 gal fuel to lube fuel system this has worked for me for many years now.
On mechanical injection pump setups a DB4 pump can be used if enough cooling is available.
