Bilstein 4600 vs kyb gas adjust gen 3
plh
I don't want to be political but this is a direct consequence of our economic inequality. People either have plenty of money and just buy new cars or they have so little money that they have to finance a new car on payments because they don't have a couple grand cash to spend on an old car that's going to need ongoing care to stay running. There's fewer and fewer in-between those extremes and it affects every market.
20 years ago when I was buying my first cars $1000 was sort of the yardstick for what could be called a "driveable" car. Anything less than that was rough, though I did own a couple $400 cars and a $700 car. But now $1000 still buys about the same (or better!) driveable car. More of us than ever live in apartments where DIY work is generally forbidden. Fewer of us than ever seem inclined to do any work. If you have a manual trans and it's not a sports car or a wrangler nobody wants it period because nobody under 40 can drive it or wants to learn. If it only has 2 doors and it's not a sports car nobody wants it even though childless couples, active empty nesters and same-sex couples are more prevalent now than ever.
It's not that nobody wants Monteros specifically it's that it's easier for most people to sign an 8 year loan for a new car than buy a set of wrenches at harbor freight and fix a minor problem on an aging car before it turns into a catastrophic problem. There's an abundance of cheap used cars on the market and yours is just another one.
Nailed it
1morebike said:
dude!
what in world holds u back? do it
its fewer than $500. and its model A simple. get your gasket set from jobbers service 80. dollars i think.
fel pro head gaskets are extra and worth it.
get a shop with import aluminum head experience to clean , surface and inspect your heads. have them put the seals in.
get new head bolts 30. i think
you will be very happy you did this your self.
i can help.
option two: get K seal or blue devil glass sealer use as directed.
they work i endorse them. poor it in, drive away.
so easy , even i can do it!
i have done it, will do it again!
