Black Friday deals on fridge/freezer?
wanderer-rrorc
Edgestar Manual
DC input power
When attempting to plug your portable freezer into a
standard 12 V socket, the unit will not work if socket has a
voltage of less than 10.4 V. The unit will restart when the
voltage is 11.8V or greater.
 When attempting to plug unit into a standard 24 V socket,
the unit will not work if the socket has a voltage of less than
22.5 V. The unit will restart when the voltage is 24.2 V or
greater.
Understanding the Temperature control setting
Your portable freezer uses a digital control system for adjusting the
thermostat.
1. SET: Set button – press this to set the desired temperature
2. Button for increasing the temperature setting +
3. Button for decreasing the temperature setting –
4. FF: Fast Freeze button – this function quickly drops the
temperature
5. “Run” indicator: this will be red when the Fast Freeze
function is on and green when the unit is running normally
6. “Low” indicator: when the power is too low, this yellow
indicator will flash
7. LED display: shows the temperature in Fahrenheit (°F)
YEP!!!
My 62 edgestar has a progamable cuttoff...and wont run untill supply voltage is high enough (I discovered that my power cable wasnt big enough and the drop across 15ft of wire would turn the fridge off)
Etoimos
I run the Arb 37qt in my JKU, full time, wired directly to the stock battery. I have no problems at all with it. Even if I don't drive the Jeep every day it still manages to keep things cold. You will have zero problems in your situation with relocating and charging daily. I'm not sure about the other brands but the Arb is incredibly efficient.
Thanks for the info on battery drainage.
Edgestar Manual
DC input power
greater.
thermostat.
temperature
What model number is that from?
TwinStick
Check out OK4WD. I got 2 fridges 50/82, free shipping x 2, free transit bag x 2, free mail in rebate/remote dual fridge monitor. I have not seen a better deal anywhere. I think it was in June though. Not sure if they will repeat that deal. Our 82 has been plugged in since the day we got it. No issues with either of them.
Etoimos
Thanks for all the info everyone. I just picked up a Dometic CFX-50W on Amazon for 25% off and Prime shipping. That was the best deal I could find.
rc51kid
Just purchased the ARB 37 from REI for about $500... They had it in-store priced at $600 on clearance and they let me apply the 20% off that they are currently running to the purchase. Not a bad deal!
I would be all over that. I looked and rei sight does not have the 37qt. How did you get one from them?
Apparently it was an unopened return from their REI Garage sale something and they don't sell the ARB 37 anymore so they let it go pretty cheap. Definitely a good deal I was more than happy to find. I actually went to that REI the day before I purchased the fridge and saw it there. But I just assumed it was one of the larger ARB fridges they sell on their website and passed it by. Decided to go back the next day for a second look and I'm glad I did.
esh
Be sure to look at the New and Used prices. Often (like now) there are models with packaging damage available listed as used from Amazon Warehouses. There is a Dometic 50W for $487 for example.
WonaWarrior
