Poor mans methanol / water injection
Poor mans Methanol / water injection:
all for under 25 dollars from scrap stuff lying around.
Intake manifold drilled for the injection nozzle.
The nozzle and holder is from an oil furnace burner.
found a 3 liter high pressure tank and made a little manifold.with a quick connect. i fill the tank about 3/4 full with water or methanol mix, put the valve back on.
i have a schrader valve hooked up to the manifold and can pump air into the tank from my compressor, CO2 tank, or any gas station air, i usually fill up past 120 or as much as the compressor can pump out.
the air pressure in the tank forces the methanol to the nozzle for a good spray. the pressure lasts quite a while if i dont fill the cylinder more than 3/4 full. i close the valve off when the pressure drops to less than 50 psi. seems to work well.
I just manually turn on the valve when i am on the highway or under higher boost.
