bought me a rubicon
gasman
well its been a while now since i picked up the rubi, and its still stock,
but.. i have been working on the trailer, i stripped it down then had it sandblasted, i changed a few things on the lid which i will post over in the trailer section,
i bedlined the frame ,fenders and lid, also inside the tub,
i can build stuff, but i am not a body man, i did my best to straighten out a few waves in the upper part of the tub, i spent 3 full days at , after pricing out the materials to paint it ,(somthing i have wanted to learn to do ) i was coming in around 250 bucks, and if i messed it up then what?
soooo.. called in a favour,and had it sprayed .i just picked it up today and i will re-assemble all the parts tomorow,
i just bought a new house with a 60x40 workshop, so once i get established there i will get to lifting the jeep
here is a sneek peek of the trailer
there are some bad reflections and some road grime but the paint is flawless
JIMBO
:sombrero: Looks good, is your JKU an auto/manual-pulling the trailer with JKU auto takes some tricks-
:costumed-smiley-007:wings: JIMBO
orangeTJ
i dont really go '' wheelin '' anymore. i would like this jeep to be my overland/expo rig, the plan is for more of this style trippin than anything else ,
Same reasons I am looking at a JKU. :sombrero:
Color matched trailer will really make a nice looking package.
gasman
what kind of tricks ? mine is auto, i have never had problems pulling with auto before, is there somthing that i should know about this, i have already made a few trips with the jku and trailer in the fall with no problems whatsoever, that little trailer pulls so nice i forget that it is there
F5driver
You can run up to 37" tires with 0 lift using tube fenders on a JK. Check out Metal Cloak, Poison Spyder or others.
JIMBO
:sombrero: Heh Heh, well they aren't really "little tricks" anymore-
You have a JK/JKU and an auto tranny-in the winter it's not that bad, but
During summer, you'll find that an aux tranny cooler is almost neccessary and when off road-except for LONG dirt roads-you should use 4lo to keep the torque conv locked and higer rpm/lower gears, to reduce the heat generated by the tranny-
You probably have the "HOT-OIL" icon warning on your dash-thats a whole new set of problems-
I've towed my trailer for over two years-up hills/rocks/snow/115° heat and had no problems--I've got aux coolers/temp monitoring-just cause I don't want my tranny failing 100 miles from Humanity !!
Google "aux cooling, JK Jeep"
Good luck
Clemtiger84
