Bought then Built XJ for EXPO and etc
Heavyopp
While your exhaust and intake manifolds are out why not pull the freeze out plugs and the 2 drain plugs
You would then really be able to clean out the water jacket around the cylinders — most likely the freeze out plugs could use a replacing anyway — use good brass plugs instead of steel
I would bet that there’s a ton of crap in there especially if you used some sort of stop leak
scrubber3
Not really here
I like what you're doing. I have an 01 XJ that I'm currently building. Just keep in mind that if your current gears are anything less than 3.73, you'll need a new D30 carrier (that's sized correctly) if you're planning in running 4.10s.
Also NAXJA is a good forum as well! Lots of great information on there.
GenPatTuck
The gingerbread man brought a long awaited piece for the XJ, its the ceramic coated exhaust manifold. JET HOT does this chrome color as well as a satin grey and then all the other colors you could want. It comes with a lifetime warranty and I cant wait to see how cool the engine is.20191014_100121.jpg
