Brake Pads for Overweight Tacoma
bkg
Tires are 235/85r16.. skinny. Light-ish, for offroad tires, but definitely way heavier than stock. (Don't remember the exact weight.. But they're just AT's.. Nothing crazy).
And about 'dangerously overweight', every tacoma w/ a FWC is in the same place.... All I've got is the FWC, ARB bull bar, and heavier tires.. No armor or other weight adding stuff. Not even a winch.. (It's still in my garage, heh). But yes.. This tacoma/fwc combo is pushing the limits. I was quite surprised when I finally weighed it...
It has served me very well, though, through rough roads and 80k miles as a camper.
2nd gen makes a huge difference. Look into the 4th gen 4runner sport that came with the 18” wheels. They have much larger rotors. @AddictedOffroad did a write up of these a few years ago. It may be you’re only real option, unless you are willing to pony up for a 1st gen Tundra big-brake option.
secondly… I’m curious why this is a concern after 80k miles at this weight. Don’t get me wrong, I think you’re way overloaded and 10 miles into “******?” territory, but why now?
wicked1
FWC's are what, like 1200 lbs....that should be within reason of GVWR, but you are another 1500 lbs on top of that. I honestly think you'd be better off streamlining your setup, sorry to offer advice you didn't ask for but there should be a lot of opportunity to cut back.
I'll take any advice :). So.. Stock Tacomas actually weigh more than they say they do. Posts on Tacomaworld show brand new off the line Taco's weiging almost 5k lbs. The FWC has a weight sticker on the side that says 1600lbs. But.. that must be empty.. As in, not even including everything they installed at the FWC factory. I already ditched the larger bed slide-out shelf and its matress. I replaced the two heavy lead batteries w/ one light lithium. Replaced the old glass and aluminum solar panel w/ a light flexible panel. I already mentioned, my truck doesn't have any other mods that add weight. (it does have an extra fuel tank which was full when I weighed it). If I knew where else to cut weight, I'd do it.
And someone else asked why now..
Well, it's just the first time I've needed pads since I stopped having Toyota do everything on the truck. Up to the 90k service, it was all toyota for everything. Oil changes, maintenance, repairs, etc. But I decided it's old enough to start doing it on my own and think about moving away from OEM stuff.. if it's a possible upgrade.
-edit to mention.. I do have a dream of some day taking out all the heavy wood cabinetry, and replacing it w/ carbon fiber or something light.. That's the only other place I can think of there being a lot of weight I could have some chance of changing.
97heavyweight
I'm in the same boat. 3rd gen Tacoma with a camper and other off-road goodies and she is heavy (not sure weight though) I just put new pads on at 70k. Bosch Quiet Cast is what I used, I have also used them on a big heavy diesel I used to tow a big heavy trailer with and they worked great.
I will most likely be upgrading the fronts to a 6 piston caliper and the rears to disks and figuring out how to get the e-brake to the transfer case. Unfortunately after the lift my e-brake like many other 3rd gens sticks and I have to go jiggle the cable running into the disk.
JaSAn
Grumpy Old Man
Something does not seem right with your camper weight. I have a FWC Grandby that weighs a little less than 1300 lbs loaded for 2 weeks remote camping (camper on truck - empty truck weight). And I used 1/2" plywood for my cabinetry and 120 lbs of batteries.
wicked1
It's a flatbed model.. Maybe they're heavier.. (well, I already mentioned the dry weight sticker is 1600lbs, so that's over your grandby. This is just a flatbed fleet model). I don't know what my aluminum flatbed weighs.. People tell me it should be the same or less than the steel truck bed it replaced.
and, that weight is just my truck and gear weight, fully fueled. But, no water or food or clothes.
It's definitely the camper, tho.. My front end doesn't weigh much more than stock.. Few hundred pounds, and that's the bull bar.
-edit, actually my custom leaf springs are huge.. They must add considerable weight. 10 thick leaves on each side.. about an 8" stack of steel.
NikonRon
I'm in the same boat but not that heavy. FWC Eagle shell model and I'm only about 600 lbs over. I'll be going with PowerBrake kit but I will also need to move to 17" wheels, though I'd prefer not to.
tlrols
This is not entirely true… i am running late model 16in tacoma wheels on my 3rd gen 4runner with the tundra upgrade.
Same here. Get Tundra wheels. Not surprisingly they work with the Tundra brake upgrade. Craigslist. I got two sets of the “Star” wheels. Very inexpensive.
tlrols
Toyota brakes are always in need of bigger. I run a Sport Edition 4th Gen 4Runner and just discovered you can upgrade its brakes to the slightly bigger and better 5th Gen brakes! Damn you Toyota…
tjalward
OK, as an owner of a 8,000 pound (when fully fully loaded for long camp trip with no resupply) tacoma that can lock up the tires on pavement, I can provide some insight from my trials and tribulations with a heavy taco. And I won't debate or argue with anyone on what I should have done, why it is so heavy, whether I should have a different truck, etc. It is what it is.
A few things that I didn't see yet - do you have a vacuum booster or the electronic booster found on TRDOR and some other models? That makes a difference. Huge difference in your options.
I have TRD sport. Vacuum booster. I started small, pad upgrade back when I was in the 6500lb fully loaded range. Sucked, downright scary in a panic stop. I tried a few sets of pads and rotors, no real difference. Although, I can tell you with confidence, the best pads I've run are the EBC orange extra duty. They are specific for heavy trucks, 4wd, larger tires, etc. With the sport rotors they made a big difference, but I never ran those in stock size (read below). I have never tried, nor will I ever pay, for the BBK stuff that is out there... way too expensive and not easy for consumable parts, etc. Truck continued to get heavier and heavier with upgrades and gear, suspension and reinforcements for the weight, cause more weight, etc... On the heaviest outing I've ever done, family of 4 for 5 days to the beach with no resupply, bringing firewood, water for showers, etc... it weighed 8300. Not kidding, on a scale. So that is some background.
The real upgrade you should look at, IMO (which you will need larger 17" wheels for):
get a late 5th gen 4 runner brake upgrade. I bought new calipers, and the EBC sport rotors and extra duty (the most aggressive pad for heavy vehicle, non race) pads for the 5th gen 4 runner. Bolted right up with trimming to the backing plate (or buy 4 runner backing plates). They have larger pistons in the calipers for more hydraulic force applied. This is a big difference but will make your brakes more soft, not only cause the larger diameter of the new caliper pistons relative to master piston size, but the EBC orange pads are a soft feeling pad as well, they bite really hard at the same time they don't feel very firm on the pedal. The TRUE best thing you can do to the brakes though, is get the dual diaphragm booster from a sequoia or tundra, and put that in. It will double the boost of the power boosted brakes compared to the crappy single of the taco. To do this, you need to get the master cylinder out of the same vehicle since the bolt pattern on the master and the booster are different. I picked up the pair at an auto recycling place. It will bolt in with mods to the pushrod and some adapters and brake line mods. There are threads on this. Getting it bled properly can be tough. When you get the tundra master, it has a larger piston. then it is assisted with a dual diaphragm booster. and pushes onto larger pistons in the calipers. Compared to stock, this will put your head passengers into the seat belt when good pads and rotors are used.
If you choose to not upgrade the wheels and therefore not get the 4runner brakes, I would still do the tundra master/booster swap. If you have a TRD offroad, I would still do the 4 runner brake upgrade, it will work with the electronic booster still. But if you are firm on staying with 16" wheels, that will be your Achilles heel. The early tundra brake upgrade that does fit in 16" wheels is nowhere NEAR as good as the 5th gen 4 runner upgrade that won't fit in the 16" wheel.
I have also gone above and beyond with the rear brakes, when people told me they couldn't be improved. Bull. I understand rears do less work than fronts, no question that upgrading something that only does 30% of the braking will not have as large of an effect as the fronts... but when you are heavier, and the weight is on the rear, I feel the rears should be upgraded too, especially when you have done front upgrades making the imbalance worse. I put larger wheel cylinders in the back, and experimented with a few different types of pads. My testing isn't complete yet, and I haven't fully documented it. But I can tell you that a wheel cylinder size increase in the back does help for a truck like ours with lots of rear weight. When I get the brakes up to temp (sometimes I drag the ebrake a bit for 1/2 mile in cold weather), I have absolutely no problem howling all 4 35x12.5 r17 mud tires on a hard stop, and it is very controllable, very low pedal pressure.
If you want to talk more details, PM and we can exchange phone numbers. That would take way less time than what I just put into writing this.
wicked1
Thanks a LOT for this reply. It's very helpful. I spent the last two days doing brake work.. Just being double sure there's no air in the lines. I got a techstream and did the ABS bleeding procedure several times. No change in performance.. but at least now I'm confident this is just how it is, and there's no air in it.
I have a base model truck, so the vacuum assist. Sounds like I have an option w/ the dual diaphragm booster.. I'll start reading about that tonight.
Then eventually, bigger wheels. I really like my tall sidewall 235/85r16's, but.. Well who knows.. I've never had 17" wheels on this, maybe I'll like it too.
I might have more questions after I do a bit of research.. Thanks again!
