bugwhacker
That's the plan anyway.
I just picked up the van tonight and drove it 80 miles to get it home.
It needs the front end rebuilt - bushings are bad and it wanders. Need to replace the column - it was damaged during a theft and isn't right anymore, plus I want a tilt column anyway.
Motor runs good and strong but dies if you lift the throttle too fast.
It is a Pathfinder conversion but the engine cradle has been really butchered, they didn't just notch it - it was cut and plates welded into it....
The original e4od trans was replaced at some time with a C-6 and a np205, I plan to put a 4r100 with PTO and some type of part-time transfer case with low reduction gears - I like the np205/203 doubler kits because its all gears and damn near indestructible with 4:1 reduction. I am open to suggestions about transfer cases and oddly this vans front fuel tank has never been cut and there is a lot of room down there?
The van is a long wheelbase model but it isn't the extended body super-van model. Is there a bolt on piece that is added to the frame to make it longer or is it a different frame? I plan to put a Falcon motor-home body on it just like in this thread - http://www.expeditionportal.com/forum/threads/62776-4x4-Camper-Van-Project-Body-Swap
I plan to take this Van everywhere as a replacement for the over-sized monstrosity I was building from a M-35 deuce and Dodge dump truck blended into a 4 door cab. After traveling around a bit in South America/Mexico I came to realize it was way too tall and way too wide and way too HEAVY - 18,000lbs, plus it only got 8 - 10 mpg at best even though it was a multifuel motor that would run on anything.
