Building a Micro-Split AC System
dreadlocks
would there be any way to just steal the compressor out of one of these and wire it up in parallel with the vehicles existing evap and condenser? or is the vehicles electric radiator fans too much wattage to make this reasonable? I'm wanting to install both shore power and engine powered AirCon into my Westy with its engine swap and since its gonna have to be all custom and I'd rather just have one condenser and evap to install.. I thought about just wiring up an AC motor on a custom bracket to a double clutch belt on the engine compressor but that seems rather rube goldberg.
dreadlocks
I'm fine with that as there's no way in hell I can fit enough solar on that lil VW to run it off battery, the radiator I'm looking at is not that big, its a little drag race radiator shrouded w/fan.. it can be powered by genset, and I'll have full control over fan speed.. but for a bigger vehicle to try solar mebe an aux fan that only runs for AC that is more reasonable?
luthj
Engineer In Residence
You will probably have to have the compressor start at full speed then switch to a slower speed. What about using a soft start that is used in RV and Boat AC systems. It will help in dropping that massive compressor surge everytime it starts up.
I don't have any issue with startup surge, as I have a 3kw inverter. I am mostly just thinking of ways to reduce cycling and power consumption when cooling just my bed area. In modest temps, such as a 80F night with 100% humidity, I may want to sleep in comfort. That doesn't need a lot of BTUs.
Its possible to plumb two compressors in parallel, however you may need check valves on their outputs. You need to choose a compressor with the correct displacement for your refrigerant. Many automotive systems have mechanical or electrical controlled variable displacement compressors. So there are considerations at play. From a technical standpoint there is no reason you cannot make a dual power system. The issue is making sure your control and air flow mechanisms work with the engine off. On something like a Vanagon Westy that's not an issue, as the system is mechanical with a expansion valve and constant displacement compressor. Just be aware that automotive systems are pretty inefficient with COPs of 1.5-2.5 at best.
tanuki.himself
There would be a marked for such a product :) Please keep us updated - if it works!
Surfy
they do exist
but very low powered, still heavy and expensive. And if the product is as bad as the web site i would avoid it like the plague....
The Artisan
Picked up some 16 and 22 gauge steel sheet and started hacking a bit.
Welding dirty 28 gauge metal is not fun with 0.03" wire, bit it should hold together.
IS there is a reason you welded it. Could it be done with sheet metal, bent sides and screwed. Looking forward to updates
Kevin
luthj
Kevin
The process could be performed using just rivets. Sheetmetal screws tend to loosen over time. Small machine bolts could work, but there is limited interior clearance in spots. I chose to weld because I had the machine setup from another project. The evap will require some different assembly, so I am considering 1/8" blind rivets to hold that together. If you plan to brake/bend sheetmetal, there are some small vice breaks which will work fine with 22 gauge. Depending on how you plan to attach the condenser unit, you could use 24-26 gauge, or even galvanized. That material is thin, so its not suited to attaching brackets for suspending a 20-25lb compressor on its own.
The evaporator needs a water tight drain pan, so you need to factor that into the fabrication. Either make a new one (or use a plastic tub?), or return the existing halved pan to water tight status. I still need to source a drain fitting, but some 1/4" steel tubing should work.
The Artisan
The process could be performed using just rivets. Sheetmetal screws tend to loosen over time. Small machine bolts could work, but there is limited interior clearance in spots. I chose to weld because I had the machine setup from another project. The evap will require some different assembly, so I am considering 1/8" blind rivets to hold that together. If you plan to brake/bend sheetmetal, there are some small vice breaks which will work fine with 22 gauge. If you Depending on how you plant to attach the condenser unit, you could use 24-26 gauge, or even galvanized. That material is thin, so its not suited to attaching brackets for suspending a 20-25lb compressor on its own.
Thanks I plan to use a catch tank for the water to reuse for shower and sink
Kevin
jmnielsen
Tinkerer
Very cool! I wanted to try something like this for my truck camper, but needed AC quick and didn't have time to mess around with this. I'm surprised there is nothing on the market in this size range for a decent price. I've seen 12v ones but they seem to start around $3k. Maybe I'll pick on up and play with it for a future build.
Alloy
Initial work on this subject is over here.
Another issue is sealing the motor on the outside unit. It will be exposed to dust and moisture. Neither end of the shaft has a seal. One side can just be capped, as I will be cutting the unused shaft off. The other side is 8mm, I think there is room to glue a shaft seal to the motor housing, and then seal the wire penetration. That should eliminate issues with dust/moisture.
We've been on trips in the spring when they spray the sufficant on the FS roads and end up with 1/4"-3/8" of mud that dries like plaster to everthing. The sufficant must be alkaline as there is electrolysis on all the aluminum.
luthj
Some have used these. Used to be available at Costco, but seems to have disappeared.
I took at a look at those. 8,000btu is a bit larger than I need. The real issue is the condenser is ~20" tall, which is not conducive to underbody mounting. The compressors are also 12-14" tall, which doesn't make for easy interior mounting once you include vibration dampening. Now I could get flexible hoses, and mount the exterior unit on a bumper swing out. But that's just a non starter for me.
My current plan is to mount the condenser centered left/right, about 24" behind the axle. The solid side will face forward. So the condenser and fan will be protected from the worst of it. I also have 11" plastic mudflaps on the rear. Depending on my experience, I may add shutters or slip covers over the side vents. I am also on the lookout for a corrosion inhibiting coating for the aluminum condenser fins. The pipes are all copper. Time will tell how long it lasts, but it was a cheap unit, so if the condenser corrodes out, I can probably swap for a similar unit. If it ends up working well I will just buy a used one to keep for spare parts.
IMG_20200714_131653625 by J Luth, on Flickr
ilciclista
