Redline
Likes to Drive and Ride
I'm almost certain Les Schwab won't have the Maxxis Bravo 761 AT treads. I did buy mine from my local Les Schwab but only because they special ordered them directly from Maxxis for me. Les Schwab recently started stocking the Maxxis Bighorn MT and a Maxxis highway tire, but not the full Maxxis line. I wanted to try the Maxxis Bravo 761 (they make them in 255/85R16) after I saw how little wheel weight was required to balance the Bighorns. If you consider ordering the Bravos from a dealer, make sure they are coming from Calif. not back east or the shipping will hurt!
The Bravo is a pretty conservative (void ratio) AT tire, but if you don't travel in sloppy terrain (mud) they should work as well as most AT tires. All 8-10-ply Bravos have a 3-ply sidewall. Regardless of the tires/brand, I really like light-truck load-range-D treads. A little stronger than a C-range without the stiffer ride of most load-range-E tires. If you get serious about the Bravos you might consider mail order from this site:
http://www.unsertire.com/Custom/Product/Maxxis.aspx
I have never purchased from Unser Tire but the price for the Bravo 761 is very good and the site says free shipping.
A supercharger for your 4.0L sounds very cool. You should have more power than my little V8 ☺
slooowr6 said:Redline,
Thanks for the detail info on Toyo and the tip on Maxxis Bravo AT. I just found there is a Les Schwab 12miles from me I'll give them a call see if they have that.
I've order a TRD supercharger and hope that will help with the power lost of 255/85/16. I'm searching a quiet/comfortable tire with some ability to go off road. All your posts about tires helps me greatly!! :26_7_2:
Still not decided on 33" or 32" but at least I got one thing down. It has to be load range D.![]()
Alex
