Great! More info piling in. Thank you everyone for taking the time to post their info and analysis and engaging in good discussion.
My conclusion is that there are pros and cons to wiring series and parallel, and apparently there is not a clear "must do" approach.
Rather, decide based on your overall plan (e.g. if you're not interested in spending extra $$$ for MPPT controller (which allows one to maximize power for a restricted area), then don't wire in series).
For my full disclosure, I DO in fact have 2X 40W panels wired in series with a MPPT controller (Sunsaver 15A). Mostly, I wired in series based on simple assumption that power is generally better transmitted via high voltage/low current rather than vice-versa (smaller wire gauge required, etc.).
However, after installation, I did find that shading DID create more loss than I expected...but my "expectation" wasn't based on any kind of data or theory or comprehensive knowledge about the cell/diode configuration of my particular panels.
I was considering rewiring in parallel based on earlier posts; however, such rewiring is not quite "plug and play" with my current setup, and would require cutting wires, (re)soldering connections, etc.
While it would be interesting to compare the two configurations in terms of power loss as a function of cell shading, I think i will have to wait for a more compelling reason to rewire everything (But yes, I truly do wish I had that much free time!!!).
Again, thanks for the great discussions!
