CAN Bus question
BLU60
2016 G550
Good day all:
I am going to install a switch panel that requires three 12V triggers. Ignition, high beams, and side marker lights.
Has anyone any experience with:
http://www.canm8.com/can-bus-interfaces/multi-output-interfaces/canm8-idr8.html
and if so where would I get the signals for this interface for this wiring harness that clamps around the Hi and low CAN Bus (instructions say it’s near the ignition key but that’s it)
http://www.canm8.com/cannect-contactless-reader/canm8-cannect-contactless-reader.html
The switch panel I am using is:
http://www.switchpros.com/
I appreciate any help. Stay tuned for a build thread!
crofrog
Did you ever move forward with the canm8 product? I'm looking at as well for adding auxiliary lights.
BLU60
I did; however, the clip on sensor could not get a strong enough signal so we had to splice into the factory bus wires. It all works as advertised. Nice to be able to link a light bar with the factory hi-beams.
crofrog
Awesome thank you!
WonaWarrior
