Can I fit a RTT on my expedition trailer?
smlobx
Wanderer
Sorry for the noob question. It I haven't been able to find an answer.
My trailer has a pair of racks that are 60" apart.
Will a RTT fit on this or are they too far apart?
Thanks.
NatersXJ6
Too far apart for most, maybe all, tents, but moving them, mounting more, or spanning them with some longitudinal rails should be doable.
smlobx
Wanderer
Thanks guys.
The trailer is a Dinot which has fiberglass sides. Internally there are some channel steel and that is what the rail brackets are mounted to. I'll look into either adding a third rail or running a pair perpendicularto the ones on there.
billum v2.0
I built the small Dinoot, worked closely with Scott to assure the fiberglass didn't crack under weight of RTT offroad. Ended up fabricating steel brackets to transfer load from fiberglass sidewalls to trailer frame.
As Frenchie wrote, third crossbar makes all the difference.
compactcamping
Eddie, Sorry did notice your post before. For a 56" wide RTTs we set crossbars 36-42" apart. For 72" wide RTTs we go with 3 cross bars. On your Dinoot, I believe the original owner added some steel framework on the sides. If so, that could be used for repositioning the crossbars
Mitch Bears
