CB Antenna ?
gary in ohio
Run a wire from the antenna mount to a near by bolt then run a wire on the inside of the vehicle near the mount to a ground point. The metal rack is bolted to a metal roof. There is a ground there, you just need to help it along and get around some rust and paint.
DaveInDenver
Middle Income Semi-Redneck
That is the ARB antenna bracket, right? My bumper mounted antenna (I only have one now, used to have two) follow pretty much what Gary says. I ran a ground strap from the frame of my truck to the bumper and then each of the mounts got a short ground strap to the bumper. I would also suggest you knock off some of the powdercoat around the hole for the antenna and the hole the grounded bolt goes through. This helped a lot for me, it seems the powdercoat is a pretty decent insulator and equally tough for the mount to bite in to. It finally took a Dremel and a mini wire wheel to get the powdercoat to come off, sandpaper didn't do it on mine. I put dielectric grease under the mount when I installed it to keep the bare steel from rusting.
hattrik21
Yeah Dave it is the ARB mount used in another way :). Gary thanks for the ideas. I'm off to get working on it now.
Jacket
2008 Expedition Trophy Champion
CB antenna revisited
I'm in the process of switching from a roof-mounted magnet antenna to a flexible whip antenna that I plan to mount to my front ARB. I plan on drilling a new hole into the bumper for the mount, and my question is whether it will make any noticeable difference in performance if I mount it near the front corner, versus mounting it in a more central location on the bumper.
By the by, it's a 4' whip with a spring and quick disconnect, plus 18' of cable.
gary in ohio
Jacket said:
I'm in the process of switching from a roof-mounted magnet antenna to a flexible whip antenna that I plan to mount to my front ARB. ..
If the SWR is good, the antenna is good for CB. Your not going to talk for more than a few miles anyway. Roof is best everything else is a compromise. You will have a better signal forward and off to one side than to the rear but more than likey you will never see the difference.
mag232
Multiple antenna roof mounts
Thanks for all the info in the thread.
I bought the 8800 and the Diamond 2m/70 cm antenna. I'll mount through the roof, no problem. I'll also want a CB and through the roof antenna. I haven't found a simple answer to the question of how to best install 2 antennas. I can put either mounts close to the center, but how do i optimize placement for both Ham and CB antennas? Thanks for any info....
DaveInDenver
There isn't really anything to optimize them so much, it's more a matter of keeping sufficient spacing. The antennas must NEVER touch, that would make for a couple of very unhappy radios. As long as you keep enough space between the two, they'll basically be ignorant of each other. Personally I find HF antennas too tall for the roof and moved my CB antenna back to the bumper. Even a short CB antenna is gonna be about 4 feet tall and I got tired of it smacking everything. For the ham antenna I have a stubby dual band that I use on the trail, it's only 19" tall and has a spring.
xcmountain80
For the time being I have eliminated use of my cb, the ham took over the antenna position on the bumper and I have a mag mount coming for the roof (little redundancy never hurt anyone). Keep thinking of where the cb antenna will be relocated. Was thinking of drilling a hole on the opposite side of the bumper and placing it there. Not related my diamond antenna recently folded (in case you go in to a garage of tree branch) going 85mph on the interstate. I wasn't sure if it was gone gone but I stopped and it was still there just folded over.
Aaron
iStan814
