quantum73
I have been lurking here for awhile and would first like to thank everyone for the great information available here.
Now, on to the reason I am posting. I recently did a SOA on my trailer and have a couple "issues". First, it seems that the e-brake cables are just a bit too short to use the original mounting brackets under the tub. Has anyone else encountered this and if so, what did you do to correct it? I would like to retain the e-brake. I have considered fabbing a couple brackets to lower the tub mounting point where it will reach properly. I have also considered pulling 2-3 of the short springs out of the leaf packs for handling purposes and thought this might allow the cables to just fit. Any thoughts?
The second question I have is regarding the SOA shock position. With the lower shock mounting bolt in place at the rear of the axle (as before the SOA), the shock is near the limits of it's compression. I see that several people have moved the lower mount in front of the axle, but it seems like the shock would be at a very poor angle to actually work effectively. In essence, it would sit more horizontal than vertical. My solution is to purchase or fab some custom shock mounts (http://www.ruffstuffspecialties.com/catalog/paired-bracket-curved-p-49.html) and weld them to the axle. I just ordered a set of the NAPA Response 94038's and this type of bracket appears to give the shocks a very good operating angle in regards to the suspension travel as well as an excellent range of motion when both loaded and unloaded. Again, any thoughts? Would anyone happen to know the axle tube diameter on the M101 stock axle?
Thanks for your time.
