With google latitude gone, (and the replacement very terrible), I was looking at some substitutes. Of course, there is the Spot and In reach, which has tracking onto a website for your friends, but maybe you don't want to spend the money, or you want something just to use occasionally when your off trail. If you need tracking off the cellular coverage area, this is not for you. For me, knowing my general bearings, and approximate location is enough for now.
Sometimes you just need to let people know approximately where your last known location was. I've been testing a few things:
Latitude: It worked well, but its no longer available. It also was reliant on a data connection. Was able to use wifi/cell tower/gps for location.
"Yoohoo"-. Its pretty simple, all it does it take your coordinates, and sends it via txt message incorporating it into a link to google maps. you can set the interval to your liking. It looks like it can use at least the cell tower and GPS, and I am still testing on the WIFI (though clearly not as important).
LocSMS: Requires GPS.
Being able to send an approximate location without GPS is important for battery life- With GPS on, I can literally see the battery life dropping in real time. Lasting a day without being next to a charger is impossible on my Galaxy Nexus. This rules out LocSMS for me.
Latitude, requires a data connection. This is fine, in urban areas, but in rural areas, I often am running the GSM phone without data; my short trips in Cambodia, where my phone worked and so did txt messaging, didn't have data roaming agreements with my U.S. carrier. Im assuming in America, that Verizon might be a better choice.
Youhoo, a free app, takes the best approximate location (either GPS or cell tower triangulation) and sends the coordinates via SMS with a bit of text to help the receiver open it on google maps. Set the number to SMS, set the frequency, your done. There's no other configuration, etc. You can also manually push a location as well.
In theory- you can save the location on the map each time if you have a google account- thereby building your breadcrumb trail. You would be able to have a time stamp (of the sms) to see when the last message was, and also when they had cell service again, and new locations being sent.
