It's good to have basic understanding of any system being used so that one can adapt as necessary.
It appears that here in the woods (literally) there are way too many dead spots in areas one would not expect which the telecom folks have yet to overcome. I have some experience operating radio, and data transmission via trunked 800mhz systems for Mobile Data Terminals, not on the tech side, on the field side. A system is set up in a new area with the best intentions of providing full coverage. The guys in the field find out wat works, and wat does not as radio waves are do unpredictable things and rules of thumb do not always apply. The techs try hard to solve the problem with limited resources. Where theory and application meet is in the field.
I'll generally go with wat works in practice fully aware of wat in theory should not. What will be passable or work in one area shouldn't necessarily be applied in another, yet all the while keeping in mind the principles upon which a system operates. There are so many variables, hills, tree leaves, temps etc, variables which have more impact on a low output system, and specific frequency range. If it did not Verizon would not such unreliable coverage!. Somebody budgeted for Wat worked in another area!.
Using a Booster in the NW, such as MT and Canada might be appropriate. Using a booster in other terrain or areas may not. It advisable to be aware of a booster's limitations, pros/cons, and strengths, the knowledge which comes in part from experience.
For me, making an emergency call with a booster available, is good insurance :lurk: .
BTW, I'm so please to have been invited to such a fine group.
