Boatbuilder79
Sure would be cool.
How come nobody makes one for the masses?
Or is there a kit I just don’t know about?
They have distinct downsides. You might read through a big truck forum to see.
Typically this requires a modified hub with air line from the body. These can catch and tear on just about anything.
The other style requires the axle to be specifically designed to accommodate the air line, with a extra set of hub seals and a rotating collar to connect the wheels air line to the axle.
Its a cool idea, and makes a decent amount of sense on big trucks where copious high pressure air is already available. But installing such a system on a smaller vehicle would add significant unsprung weight to the axles, and introduce new failure points. Multiple seals that could fail and deflate a tire, numerous valves which can seize up, or freeze if water gets into the system.
If you go the external route, there is a line on the outside of the wheels which will rip clean off if caught on a branch or rock, could get pinched against the wheel, or even just damaged by spinning through deep sand.
Its kinda like put 40" tires on your rig. It may look cool, but unless you have a rig that demands it, you are going to regret the trade offs.
Dana Spicer had a prototype kit at EJS like 2-3 years ago that just bolted right into a Jeep JK.
It seemed to work just fine and was minimally obtrusive as far as mods.
In Iceland such systems are fairly common on vehicles that go onto the glaciers.
it seems like that would sell. I wonder why it isn’t in production.
