Charging Both Ways
VerMonsterRV
Gotta Be Nuts
Mine leaks at the same place and it is a new pump! Grrrr!
Well, at least it is a simple/cheap fix. Ours was the older style with a 22mm bore. The newer ones use 16mm. If yours is 16mm parts are easy as it is generic across lots of trucks. If the 22mm you need an adapter bushing to go from 22mm to 16mm. If you send a picture I can probably tell which one you have. After getting the parts it took about 10 minutes to swap out.
DiploStrat
I am planning to take the truck to these folks and will roll pump leakage into the process.
Getting too old and ugly to do it myself if I am not broken down in the bush. I am just looking forward to access to lots of parts! ;)
WonaWarrior
