Tom Foolery
Tom,.... What was some of the factors that determined air shocks over gas for your set up? any info would be appreciated
I wanted a little adjust-ability to the ride height when hauling heavy loads. That is all. You will really like the travel that you are going to have with those leafs and I see you have bump stops too, good move. If you want a real stiff ride, might I suggest Monroe Sensa-Trac Load Adjusting Shock Absorbers
![mon-58647st_xl_jpg.png mon-58647st_xl_jpg.png](https://expeditionportal.com/forum/data/attachments/643/643338-cfdc25c54db4ebdb88b886b9665f2b56.jpg)
But buy the shocks before you plan your mounting points and shock tab widths, they are large and don't compress easily and will lift your trailer much higher then you might like. I had some, but sent them back for that reason. My trailer had a four in lift with them haha.
:ylsmoke:
