JDEAN85213
I have a Chinese diesel heater that I planned on powering with my portable battery pack. The battery pack is a FlashFish 166Wh that says the DC output is up to 10 amps at 9-12 volts. BUT, the heater shuts itself down for not having enough power.
The heater only draws maybe 9 amps on startup and then less than 1 amp after the glow plug turns off. I would think this battery would power the heater for a night.
Can anyone suggest a workaround? Maybe using the built-in inverter instead and convert back to 12v?
Currently I'm successfully using the heater hooked up to a marine battery but I would rather only use the portable power supply bc I can charge it with solar.
Sent from my LM-K300 using Tapatalk
