SkiFreak
Crazy Person
From what I have seen with the majority of Chinese winches, the grease they use is not what I would call "high grade".
Personally I believe that the first thing you should do if you buy any of these Chinese winches is to strip them down, clean everything up, check everything out (Chinese QA is a bit questionable) then reassemble with a good quality high pressure grease.
The Runva winches are probably one of the better Chinese winches, in fact, that is what I use on my truck. However, they are cheaper for a reason.
As an example... on my 17,500lbs front winch all of the bolts that secure the motor and gearbox simply screw into the cast iron. Cast iron is not a brilliant structural material, so it is very easy to strip these threads out if they are over tightened or get put under high loads. I have Loctited helicoils into all of my threads, which makes the whole setup significantly more robust.
I also run the winch rope out on a semi regular basis and check overall functionality, as I consider this part of my normal maintenance routine.
I do not know if any of this is relevant or not to the failure that MAB had with his winch, but I thought I would start a thread where we can discuss this, opposed to hijacking the "FG's For Sale" thread.
After all, a winch is a piece of recovery gear that needs to be reliable, so making it as fault tolerant as possible seems like a no brainer to me.
