coffeegoat
I'm in the midst of my tear down for my engine refresh (timing belt, valve seals, head gasket, etc) and because I've only got a couple of hours at a time last night I finally got the air intake manifold off. It looks horrendous...
Certainly it needs a bit of a cleanup, but my question is how clean should I make it, and is there a best tool to do so.
My intention is to try simple green first, followed by brake parts cleaner to strip off as much of the varnish as I can, and then look upstream and downstream as much as possible for other stuff to clean up, is there a better way to do this?
Also, it seems dirtier than I would expect for an intake manifold, any thoughts on why?
