BrandX said:
so then i guess that will work. do they bolt up or is theresome modifying? :Mechanic: could you take some pics of them. that might answer my questions.but yeah that may be the route for me. how much for the coils?:jumping:
I have heard that they do. Just to be sure, I PMd a buddy of mine that knows for sure, DevinSixtySeven. Hopefully he will chime in here. I'll get a picture of them up for you this afternoon (off the truck), but you can see them on the truck at the link below.
So you know, the RevTek spacer lift kit comes with two rings. One goes between the coil and top plate and pre-loads the coil. The other goes above the top plate and beneath the top mounting location. The former is about an inch thick, and the latter is about 3/8" thick. With the geometry of the suspension, they combine to lift the front of a Tundra 2 1/2". The shop that I had install mine the first time, left the top spacer out and I had to go back and make them install it, too. (I have no idea why they did that.)
I will get these cleaned up and fire over a picture this afternoon.
Here is what they looked like going on. Note the two spacers in the photo at the top of the shock mount. The black one is a Daystar urethane spacer (not for sale - it's on my truck above my Camburg's) and the aluminum one is the RevTek preload spacer. This was before they put the 3/8 inch spacer in.
I hope this helps.
