AFBronco235
Crew Chief
Think of it this way. Each antenna is like a light bulb. Instead of radio waves, they send out light. The brighter the light you could see, the better the reception would be. By placing one back and one front, you can see light (get reception) from both directions. If they're only mounted on the front, as I have now, then you won't get much reception to the rear. Mounting one at either end, and towards the corner of the vehicle, provides maximum area coverage.
Now I will say this, truckers mount dual antennae as far apart as possible, usually on their mirror frames. This pushes them out away from the truck enough to reach around the back of the trailer. About the only blind spot from that setup is a few hundred feet directly behind the trailer they may be pulling. However, a semi isn't expected to go places an ambulance would need to go and so doesn't need to worry about snapping antenna off in say a suburban area with low tree clearance, or maybe a parking gargae. So, my point stands about mounting antenna at opposite corners and using springs. This minimizes blind spots on a vehicle like a boxy ambulance, while still avoiding clearance issues mentioned above.
