I'm going to go against the grain here, or at least, provide a different light on the MV50. I have one, it worked okay for a while, but they don't like high pressure. Mine worked good up to about 40psi when it was new, then slowed down drastically. I used it once to inflate 2 235/85R16's to 80psi and I've used it a couple of times to take 2-255/85R16's tires up to 60 psi. It took 10-15 minutes per tire to go from 35 (normal rear tire pressure for me) to 60 psi (max. pressure for my tires, 255/85R16's). I also used it a couple of times to air up the 255's from 20 psi to 35-40 psi per tire (all four). The pump is dead now. I'm not sure why, I haven't taken it apart yet. However, the last time I used it, it refused to inflate my tires over 30 psi. And it took 45 minutes to get them there from 20 psi.
My words of caution on the MV50: if you aren't going to fill your tires much over 30 psi and you give it time to cool down in between tires, it should do you okay. If not, your money will be better spent on something else.
