Hilldweller
SE Expedition Society
We've all done a bunch of things and they seem to always be "works in progress"...
But here are a few things so far that will stick. I think.
Shelf over fridge with tie-downs:
Kitchen shelves. Top left is home to the grill for the fire, griddle, & frying pan. Under that is a tight-fitting cubby for the stove. And on the right is a larger hole that has two tupperware bins that hold the espresso pot, coffee, tea, poptarts, and other what-nots that are needed fast. Under the stove is the paper towel hanger that folds up to hold everything in:
Receiver under tongue; can mount a lunette ring, Max Coupler, or regular hitch. This evens out the whole affair too:
License plate on hinge; to get to the pole box:
Quick-Fist Mounts for real axe and shovel:
LP tanks to the rear; reduce tongue weight; also got rid of the 7 year-old AT tires that had suspiciously dry sidewalls and mounted Mud Rovers:
Bedroom awning. Pole through the end, hole drilled at each end, telescopic WallyWorld poles held in place with bungeeballs:
And I've taken a blade to the bar and cutlery areas and hacked away at the foam. Paper plates and different pots, few cups, etc, etc.
A tweak here and a tweak there to make it more livable.
