I'm rewiring my truck camper and adding a fuseblock to the system. I have a question about the wiring flow. I plan to have my 100 watt solar system feed my single battery. From there the power will feed the fuseblock and all the lights, fan, and fridge, etc... coming from that block. My fuse block has a built in buss bar so all the negatives will be run back to the fuse block then return to the negative terminal on the battery.
I want to be able to run all my acessories off of shore power so I need my converter in the system somewhere. I just don't know where to put it. Should I wire it into the system before the fuseblock or do all of the acessories need to be wired directly to the converter?
