Couldn't afford a Taco, so I got a Dako: 1st Gen Dakota Budget Build
DaveInDenver
Middle Income Semi-Redneck
Then don't go with the solar. Just my $0.02. Putting in an isolator requires the engine to be running to do any charging since all it's doing is protecting the starting battery. You then have to run suitable cable to the remote battery. I used 2 AWG welding cable that was about $2.50 per foot, so to the bed and back is probably gonna be $50, $100, I dunno, maybe more. The ML-ACR I have was $175 since I have a dual battery try under the hood it was just making an extra large tray and hold-down. Even with all that I still run a portable solar panel and controller in camp so I don't have to worry about starting the truck until I leave, my fridge battery only last a couple of days on its own. Since it's continually charging the draw is low so the cable I used was 12 AWG and I got a 100' spool for quite a bit less than the 20' of welding cable. I used that welding cable to wire the batteries together, upsize the starter lead, the alternator lead and the main engine ground.
DaveInDenver
This is what I put together, if it helps. Keep in mind I already had stuff like the crimpers for the cable lugs (those were $200 alone, plus each lug is a few dollars).
DaveInDenver
My wire runs along the frame rail from the engine bay, passes through a hole I drilled and into a fuse block in my bed. Since I have a newer Tacoma the bed is plastic, though, so rust isn't a concern. A small hole with a grommet shouldn't be any trouble, though.
ADDvanced
Ordered a upper/lower radiator hose, thermostat, and serpentine belt for the upcoming trip. Haven't decided on aux lighting yet, but I definitely need to relay the headlights. I wish there was a 9004 relay kit available; I can do it but I'm short on time.
The biggest issue at the moment is the compression seal/compression boot between the topper and the cab; the lower radius does NOT match the shape of the window. When I installed the topper, I used ratchet straps through the front windows to pull the topper forward tightly, but it isn't enough.
Water will run down the outside edges, then wrap inwards and come in the bed where the seal joins together in the middle. It actually pools up a bit in the center of the seal, when you're inside the truck.
I sketched a quick diagram of the situation and attached it.
Options as I see it:
1: Remove topper, apply giant bead of silicone, reinstall and hope for the best
2: Remove topper, remove seal from topper, grind out lower corners to more closely match radius of rear window, spend $75 on new, slightly longer seal, reinstall
3: Attach trailer full of gasoline leaf blowers connected to bed with hoses to maintain positive pressure inside bed like Roadkill's backyard supercharging episode
Any ideas? Again, new to trucks, I had no idea that toppers without forward facing glass were even a thing. I like the concept of it though; I can keep the AC on, open the rear window, and now my doggo isn't in an oven.daktoppersealdiagram.JPGdaktoppersealdiagram.JPG
02rangeredge
Goal: To build an ultra mild, cheap camping rig out for use in a 3500 mile roadtrip scheduled for early next month (Sept 2018)
Truck: 1994 Dakota SLT Club Cab, V6, RWD, Open Diff (!), auto
Background: So this is my first truck, but not my first build. Here are a few links to some of my current/past projects:
Current Garage Build Outs on Garage Journal
3800 Sq Ft Warehouse Apartment Build Out
Story: Typically I tow everything with my 95 S6 Avant; My sleds, my boat, and my utility trailer. I've never owned a truck and honestly the brodozer culture here in the midwest made me hate most trucks. However, my S6 blew a headgasket and I'm rebuilding it with a bigger turbo, so I needed a tow rig that could also haul building materials. I searched for months. I tried fullsize trucks (F150s, 1500s, Rams) and found them way, way too big, way more truck than I need or ever want, and I tried compact trucks like Rangers/S10s and found them cramped/tiny. I really, really wanted a Tacoma, but living in the salt belt has seemed to make this dream impossible, for now. I looked at so many, but all of them were rotten garbage or way out of my price range.
Enter the Dak.
I picked up this truck back in March of 2017 for $1800. It was a one owner truck, garaged it's entire life, owned by a Pastor near Milwaukee, WI. He wound up being put in an old folks home, so his family donated the truck to charity where it was sold at auction, purchased by a dealership, who then sold it to me. The paint is in amazing shape, and so was the interior. I think the truck was sitting a while, so I immediately changed the fluids, filters, shocks, etc. The A/C wasn't working, so I recharged it with a kit from wally world for $22 that included some sort of sealant, and it's still working great 1.5 years later.
Last year, I had a trip planned out to CO and I wanted to take this thing up into the mountains on some mild roads, so I had built a plywood raised floor/2x4 cross beams, but unfortunately that trip never happened: My GF was diagnosed with Stage 3 breast cancer and we had to cancel our trip, she had to start chemo immediately, surgery, radiation, all that fun ****************. The past year has been pretty rough, but she's fixed/repaired/recovering and we are continuing with the plan a year later.
So I liked the truck, but was really hoping to find a clean V8/4x4 version. Again. Rust belt. Most of these trucks are beyond trashed. I gave up late last fall/early winter, since I knew I would be towing my sleds a few times, and wound up getting some Kuhmo AT51 all terrains.
Stoked about these! They're also 'snow rated', and I've had bad experience with regular all terrains in the white stuff, but these things are awesome. BARELY louder than stock, great grip in any condition so far, boat launches, 1ft of snow, etc. With some sandbags in the back and these tires I honestly didn't feel like I needed 4wd.
Recently, I had a gas tank strap fail, and my gas gauge never worked anyway, so I decided to pull the bed, replace the straps, and replace the pump/sender. This rapidly spiraled out of control. I built 2x4 scaffolding, and raised the bed a corner a time, raising some cross beams. Hood AF but hey if it works it's not stupid, right?
I then aired out the rear tires and drove the truck out from under the bed:
And since I had the bed off, I might as well wire wheel all the scale/corrosion off the frame, right?
And then paint it all with rust reformer...
And then paint 2 coats of thinned out, semi gloss black rustoleum:
And put it back together:
Anyway, that's the truck so far. In terms of plans, I'd really like to locate an LSD that would bolt in, but it seems like most places want $600 to install it. I hate the idea of spending $4-500 on an LSD or auto locker, then another $600 to install it, but I might just bite the bullet. I figure a good LSD/locker and maybe a recovery winch should get me most places, I'm not going to go anywhere too wild.
So far, here are the rough plans, gentlemen:
- Raised Bed + Storage (done)
- Cut to fit yoga mat material on raised bed
- Dog friendly screen material in the rear sliding windows, WITH regular bug screen
- Transmission cooler
- Relay for headlights (melted a headlight switch already, sucked to replace it)
- 12v Battery in the bed with solar array on the top of the cap, charge phones/run fan/mini fridge
- Light Bar
- Recover points in the front/rear bumper (D rings, I think they are called?) with a recovery ratchet. I thought about getting a front winch, but nobody makes a mount for this thing and I'm not sure I'll have time to fab something.
Thanks for looking, and stay tuned for more updates over the next few weeks.
Have you thought about a front hitch receiver for the winch? then you can just run wiring front and rear and get your hands on a receiver cradle and you'll have a front and rear winch
ADDvanced
Last Thursday, I wound up pulling the bed again, twisted the fuel sender/pump by 5-10 degrees, and bam, fuel gauge started working again.
For the compression seal, I think I fixed it. I pulled the topper, pulled out the seal, and used a jigsaw to make the lower corners a tighter radius. I made them go a bit lower and more outwards than the rest of the shape, to get the seal around the rear window frame. I reinstalled the compression boot, but now I had another problem: There wasn't enough of it.
A new seal would be ~$70-100ish, and cmon, this is a budget build! After hunting around at hardware stores, I wound up with a $10 roll of 'flex tape', it's a butyl rubber tape with some crazy adhesive on it. I threw one strip on the bottom of the gap, then filled it with strips of tape.
I then wrapped one long piece across basically the entire bottom, but I forgot to photograph it. It came out awesome! It flexed just like the original seal, super pissed I forgot to photograph it! Anyway, reinstalled the cap on the bed, again with ratchet straps pulling it forwards. Added a bit of silicone on one pesky gap, so it should seal pretty well now. I had a clunk in the rear end so tightened the piss out of the shock bolts, seemed to help.
Shocks/Brakes next!
ADDvanced
Update: Fuel gauge doesn't work. Again. I ************** give up. So pissed. It will read full, but after driving 300 miles it reads 3/4 full. I've removed the bed TWO times now, to try to fix this issue. Donezo. Will fill up every 300 miles and I'm not touching it again, have already wasted god knows how many hours.
In other news, I added some additional lighting. I'm already runny sylvania Xtravision bulbs, but the lights were still sort of poor. I added some 6" Hella500 Free Forms. Instead of removing/drilling the bumper, I snagged a license plate mount for $16 shipped; figured it was quicker than fabbing something and it's already powdercoated.
SCR4TCH
Way late to the game here but awesome truck! My first truck was a '96 4x4 ext. cab with the V8. I have dreams of buying one again some day for similar reasons as you (mild exploring, nice usable size). Also like you, i live in the rust belt so by the time I have disposable income, finding one that's within my realm of restoration abilities will be a chore. Anyways, nice write up and congrats on making the trip.
