Cowboy 4x4 off road CT build
cowboy4x4
today I rewired the rear door lights, they were wired at the bottom from the factory so I had to re route the wires to the top since I made the door hinge at the top. I also added a utility light in the door on the inside.
Mark Harley
Very nice! Instant awning.
Let's see the new wheel and tire pictures.
Will you be painting or wrapping the trailer?
cowboy4x4
I painted the roof tan.... the silver was like a mirror with the sun.
installed some fender protection as well, trying to keep the rock dings at a minimum.
until I can get some new rims and tires I just painted the rims black.
cowboy4x4
Graphics/paint on the sides will be the last to go on as I have to install a side door and two windows. I'm also installing a recessed propane tank in the side as well.
Box Rocket
What are you using for the fender protection and where did you get it? Thanks
cowboy4x4
weeelllllllll...... it's actually grip tape for skateboards. Any skate shop and possibly bike shops will carry it. Just so you know make sure you put it on straight the first time because it is a ******** to try and get off. Home depot used to carry something similar but it wasn't as wide. I think this was 9 or 10 inches wide. I had to narrow it down and I rounded the corners. It comes in several colors as well as jungle camouflage.
cowboy4x4
80 watt solar panel with morning star controller for base camp.
10 watt solar panel battery tender for when trailer is stored at home.
cowboy4x4
Haven't done much to the trailer lately, work has been slow gotta watch what I spend. I noticed that while driving over bumps the water cans in the holders would clang and rattle. Upon pulling them out I saw that the paint was wearing through from the rubbing. I used some 1/8 rubber on the bottom and some 1/16 thick on the sides. That should keep everything in good working order.
quigleyth
