CPT Truck Utility Box vs. Tufport
Cummins_expo
Biggest difference is construction methods- CPT uses a composite sandwich and extrusion joints. The one you linked is the EMS unit. It has an aluminum outer and I believe core with FRP inner. That one is designed for occupancy ( roll-over). They have a "recreational" unit that uses a foam core with FRP skins.
These popped up on my fbook the other day. Cost wise it looks doable. Not sure about the EPS foam as a core though.
Thoughts from the experts?
Smudge12
