Ok so I've had now two alternators go bad within 6 months of installation, the first was definitely because of oil leaking from the cam seal, I've since replaced those seals and timing belt, water pump, etc. I flushed the cooling system because it was due. Now I can't say about before because honestly I never paid attention to the temperature of the engine bay as I would always let it cool down before working on it, but this time I was like there must be something else since other members have reported going through alternators like I have, also read about exhaust manifolds cracking; then yesterday while waiting for my wife outside the doctor's office I noticed my temp gauge climbed up rather quickly (I hardly ever have a reason to wait for someone that long inside the car with the ac on), also the ac cold air got warmer really quick, now I know this is Houston and is hot but none of my cars AC have ever acted like this without having some sort of AC issues. Then I got out to open the hood and the hood support rod was too hot to touch and the engine bay was almost like a BBQ grill hot, I have opened the hood of other cars I have owned while hot for one or another reason and this is the first time I felt I was going to get a burn just by opening the hood. So now I'm leaning towards testing for leaks in the exhaust manifold, which I will do later on today.
1- Am I right to believe that heat soak would also be the reason for my alternators going out? I can always replace it since I got the lifetime warranty, but I want to fix the heat in the engine bay as it also affects my AC.
2- I have seen cast iron manifolds on ebay, anyone here got them on yet? I know is flea bay, but at that price range I might try it and report the outcome if no one here has tried them.
3- I will also test the clutch fan, any other suggestions?
