dorifto-san
Creeper
1998 Gen 2.5
I was pulling out of my driveway a couple of weeks ago and lost power steering temporarily. I figured it was cold and maybe the fluid was just really viscous, then about 2 blocks later I completely lost steering and my battery light kicked on. By some miracle I was able to drive it back home and into my driveway. I popped the hood and noticed that none of my pulleys were turning. I shut it off and manually moved all the belts and pulleys, so nothing was locked up. I know the crank pulley bolt is a common issue for these engines but the prior owner told me he already updated the bolt and did the timing belt. Long story short, he didnt.
Thankfully the timing belt didn't slip off, but the crank pulley pin sheered off and I have a decent amount of leaks behind the timing cover. Soooo, I'll be doing my timing belt, water pump, crankshaft seal, front and rear cam seals, belts, hoses, updated crankshaft pulley bolt/washer, new pulley dowel, etc...
Yay.
I'll post up pictures in a little while.
:smilies27
Yay.
:smilies27
