Creative ways to get height at rear axle?
1stDeuce
If you want to add carrying capacity, then air bags are nice... Either buy the set linked in the article above, or call AirLift's tech line and they can probably hook you up with a set that will work. They'll want to know some measurements like coil dia and height of the space the bag would occupy.
That said, I would not recommend air bags if you just want lift height. Better to do that with spring spacers. You just need to know the dia of your coils to find a spacer that will work...
borison
Would this 2.5" thing work? It says it's "universal" and looks like it'd be easy to just slide in there:
http://www.jegs.com/i/JEGS-Performa...ap3rVykrRde2P9GIOPLtUNNUiP5n_y-RoCclsQAvD_BwE
I tried them on my Subaru Outback before I got the spacers for the top of the struts. They did not work at all, slipped out too easy. If you have struts, you may be able to fabricate similar(to the Subaru) spacers for the struts out of metal or more easily out of HDPE.
